ASUS VA247HE Eye Care Monitor features 23.8-inch Full HD (1920 x 1080) 178° wide viewing angle panel, providing vivid image quality. Up to 75Hz refresh rate with Adaptive-Sync/FreeSync technology to eliminate tracing and ensure crisp and clear video playback. In addition, it also features TÜV Rheinland-certified Flicker-free and Low Blue Light technologies to ensure a comfortable viewing experience.
Product Description | ASUS VA247HE - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class F | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 54.135 cm x 20.594 cm x 40.364 cm | Weight | 3.25 kg | Compliant Standards | TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | VA |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, Flicker Free technology, Colour Temperature Selection, Low Blue Light technology, ASUS EyeCare+ Technology |
Dimensions (WxDxH) | 54.135 cm x 20.594 cm x 40.364 cm - with stand |
Weight | 3.25 kg |
Connectivity | |
Interfaces | HDMI , DVI , VGA |
Mechanical | |
Tilt Angle | -5/+23 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 22 kWh/1000h |
Power Consumption (Typical) | 17 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.135 cm - depth: 20.594 cm - height: 40.364 cm - weight: 3.25 kg , Without stand - width: 54.135 cm - depth: 4.944 cm - height: 32.541 cm - weight: 2.87 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 59.9 cm |
Shipping Depth | 12.7 cm |
Shipping Height | 41.5 cm |
Shipping Weight | 5.18 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
