The frameless ASUS VA27EHE eye care monitor features a 27-inch IPS panel and 178° wide viewing angle for a vivid image quality with minimal color shift. Eliminate tracing and ensure crisp and clear video playback with its featured Adaptive-Sync technology and refresh rate of up to 75Hz.
Product Description | ASUS VA27EHE - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Power Consumption (On mode) | 23 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.3114 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Colour Support | 16.7 million colours (8-bit) | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.224 cm x 23.994 cm x 45.373 cm | Weight | 4.64 kg | Environmental Standards | TCO Certified Displays 8, ENERGY STAR Qualified | Compliant Standards | UL, TUV GS, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, ISO 9241-307, KCC, WEEE, E-Standby, CEC, UkrSEPRO, KC, RCM, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 24 - 84 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Adaptive-Sync technology, Colour Temperature Selection, Bluelight Filter |
Colour | Black |
Dimensions (WxDxH) | 61.224 cm x 23.994 cm x 45.373 cm - with stand |
Weight | 4.64 kg |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
Tilt Angle | -5/+23 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 23 kWh/1000h |
Power Consumption (Typical) | 30 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.224 cm - depth: 23.994 cm - height: 45.373 cm - weight: 4.64 kg , Without stand - width: 61.224 cm - depth: 4.89 cm - height: 36.667 cm - weight: 4.03 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 68.4 cm |
Shipping Depth | 14.6 cm |
Shipping Height | 47.1 cm |
Shipping Weight | 6.14 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
ENERGY STAR Certified | Yes |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
