Asus VC239H 23" 1920x1080 5ms VGA DVI HDMI IPS Monitor
23" SLIM BEZEL, IPS MONITOR
£133.32
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Exclusive GamePlus function
  • Vivid, lifelike visuals
  • 80,000,000:1 ASUS Smart Contrast Ratio
  • ASUS-exclusive VividPixel technology
  • Image quality mainly depends on panel itself
  • Blur happens if original quality of an image is bad
  • Usually people don't notice this detail because no comparison was made
  • Monitor without VividPixel
  • In-Plane Switching technology panel known for its excellent image quality
  • VividPixel default at 25 automatically fine-tunes image quality
  • See more differences by choosing among 5 options in VividPixel setting
Product codes
VC239 series feature with In-Plane Switching technology panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
Exclusive GamePlus function hotkey to enable OSD crosshair and timer functions. Select from four different crosshair to suit your gaming environment, and keep track of spawn and build times with the on-screen timer.
The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
ASUS VC239H - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
53.32 cm x 19.955 cm x 38.317 cm
3.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, TUV, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VC239H 23" 1920x1...
£133.32
