VC239 series feature with In-Plane Switching technology panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
Exclusive GamePlus function hotkey to enable OSD crosshair and timer functions. Select from four different crosshair to suit your gaming environment, and keep track of spawn and build times with the on-screen timer.
The VividPixel Technology enhances outline, sharpness, and color saturation of images and videos to deliver high-quality visual experience.
Product Description | ASUS VC239H - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class A | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 22 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2652 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black | Dimensions (WxDxH) - with stand | 53.32 cm x 19.955 cm x 38.317 cm | Weight | 3.4 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, TUV, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ErP Ready, CEL level 1 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Viewable Size | 23" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, input select |
Features | HDCP, frameless, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ultra wide viewing angle, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Slim Design, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology |
Colour | Black |
Dimensions (WxDxH) | 53.32 cm x 19.955 cm x 38.317 cm - with stand |
Weight | 3.4 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.5 Watt |
Connectivity | |
Interfaces | DVI-D , VGA , HDMI |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x DVI cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 53.32 cm - depth: 4.575 cm - height: 38.317 cm , With stand - width: 53.32 cm - depth: 19.955 cm - height: 38.317 cm - weight: 3.4 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
