The ASUS VivoBook Pro 15 is a slim and lightweight high-performance laptop that's powered by advanced processor. It features a crisp display with perfect color gamut, high-quality gaming-grade graphics, audio co-developed by Harman Kardon, and cooling and fast-charge technologies.
Product Description | ASUS VivoBook Pro 15 N580GD-DM230T - 15.6" - Core i7 8750H - 8 GB RAM - 1 TB HDD | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache | Memory | 8 GB DDR4 (2 x 4 GB) | Storage | 1 TB HDD / 5400 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane)) | Optical Drive | No optical drive | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA GeForce GTX 1050 | Video Memory | 4 GB GDDR5 SDRAM | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell | Security | Firmware Trusted Platform Module (TPM) Security Chip | Colour | Gold and metal with hairline finish | Dimensions (WxDxH) | 38 cm x 25.6 cm x 2.05 cm | Weight | 1.99 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
Cache | 9 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM175 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 1 TB HDD SATA / 5400 rpm |
SSD Cache | 16 GB 3D Xpoint (Optane) (M.2) |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Features | Ultra Slim Design, anti-glare, 45% NTSC colour gamut |
Audio & Video | |
Graphics Processor | NVIDIA GeForce GTX 1050 |
Camera | Yes - HD |
Sound | Harman/kardon stereo speakers, microphone |
Audio Features | ASUS SonicMaster |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11ac, Bluetooth 4.2 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 47 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 120 Watt, 19 V, 6.3 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , HDMI , LAN , USB 3.1 Gen 1 , USB-C 3.1 Gen 1 , 2 x USB 2.0 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Case Material | Aluminum |
Features | Fast charging |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | UL, BSMI, CB, CCC, FCC |
Dimensions & Weight | |
Weight | 1.99 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
