ASUS VivoBook 15 is the perfect combination of beauty and performance. Powered by modern hardware, it's the ideal laptop for daily computing and entertainment.
Product Description | ASUS VivoBook 15 X542UA-GQ116R - 15.6" - Core i5 7200U - 4 GB RAM - 1 TB HDD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 4 GB DDR4 | Storage | 1 TB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11ac, Bluetooth 4.1, Gigabit Ethernet | Battery | 2-cell | Colour | Matte silver IMR (top), matte dark grey IMR (LCD cover) | Dimensions (WxDxH) | 38 cm x 25.1 cm x 2.32 cm | Weight | 2.3 kg |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Storage | |
Main Storage | 1 TB HDD SATA / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Features | ASUS Splendid Video Intelligence Technology, anti-glare, 45% NTSC colour gamut, ASUS EyeCare Technology, Tru2Life |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - VGA |
Sound | Stereo speakers, microphone |
Audio Features | ASUS SonicMaster, ASUS AudioWizard |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11ac, Bluetooth 4.1 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 38 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , VGA , USB 2.0 , HDMI , LAN , USB-C 3.1 Gen 1 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | System password, ASUS IceCool design, ASUS Battery Health charging technology |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2.3 kg |
