Asus VivoMini VM65N Intel Core i5-7200U 8GB 128GB 1TB Win 10...
Asus VivoMini VM65N Intel Core i5-7200U 8GB 128GB 1TB  Win 10 Pro
Key features
  • Vivo DualBay accommodates up to two storage drives for added flexibility
  • Ultra-fast data transfer speed with SuperSpeed USB 3.1
  • Intel 802.11ac Wi-Fi card and ASUS Media Streamer for 4K UHD streaming
  • Integrated speakers with SonicMaster Technology-enhanced audio
  • Compact VESA-mount-compatible design lets users create their own custom all-in-one PC
Product codes
ASUS VivoMini VM65N is a 2-liter mini PC that features the latest Intel'Skylake' processor architecture to deliver maximum performance while taking up as little space as possible. It is powered by a choice of 6th-generation Intel Core processors, and features discrete NVIDIA GeForce graphics for smooth 4K UHD visuals and casual gaming. In addition, SonicMaster audio and DDR4 RAM make it a wise choice for a daily computing platform or entertainment hub. Its compact design even houses Vivo DualBay to give you flexible storage options - you can choose between 2.5-inch SSDs or HDDs so you can speed up your operating system or have space for your movie and music libraries. It delivers superfast connectivity too, thanks to SuperSpeed USB 3.1 and 802.11ac Wi-Fi. VivoMini VM65N features a Zen-inspired spun-metal finish and an elegant Iron Gray color scheme. This stylish and well-crafted mini PC is a wonderful addition to any room of your home.
VivoMini VM65N comes with built-in SonicMaster speakers right out of the box so there's no need for external speakers. ASUS SonicMaster technology, tuned by the renowned ASUS Golden Ear team, gives you deep rich bass and crystal-clear vocals - all from a mini PC.
VivoMini VM65N features Vivo DualBay, a unique dual-storage design that can accommodate up to two 2.5-inch solid-state (SSD) or hard disk drives (HDD), or a single 3.5-inch HDD for added storage flexibility. So whether you're after larger storage capacities or faster data access speeds, you can mix and match between SSD or HDD options to better suit your needs. If you're looking for space to house your movie or music libraries, use a single 3.5-inch or two 2.5-inch HDDs. Alternatively, you can choose a combination of 2.5-inch HDD and SSD for faster data access to speed up your operating system.
Product Description ASUS VivoMini VM65N - mini PC - Core i5 7200U 2.5 GHz - 8 GB - SSD 128 GB, HDD 1 TB
Type Personal computer - mini PC
Processor Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) (Dual-Core)
Processor Main Features Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory 3 MB
Cache Per Processor 3 MB
RAM 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive SSD 128 GB - SATA 6Gb/s - 2.5"
Hard Drive (2nd) HDD 1 TB - SATA 6Gb/s
Optical Storage No optical drive
Card Reader 4 in 1
Multi-GPU Configuration 1 single GPU card / integrated GPU
Graphics Controller NVIDIA GeForce 930M / Intel HD Graphics 520
Audio Output Stereo
Networking GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
OS Provided Windows 10 Home
Colour Iron grey
Dimensions (WxDxH) 19 cm x 19 cm x 5.62 cm
Weight 1.2 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
