This LCD monitor from ASUS provides a crisper, broader, and brighter display, plus a host of features that enhance your viewing experience. With these features, you can enjoy the convenience and delightful visual experience that the monitor brings to you!
Product Description | ASUS VK228H - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class A | Energy Consumption per Year | 29.2 kWh | Power Consumption (On mode) | 20 W | Features | Stereo speakers, camera | Panel Type | TN | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 2 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 51.4 cm x 20 cm x 38.55 cm | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | FCC Class B certified, UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, RoHS, WEEE, GOST-R, J-MOSS, EuP |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Viewable Size | 21.5" |
Built-in Devices | Stereo speakers, camera |
Panel Type | TN |
Pixel Per Inch | 102 |
Vertical Refresh Rate | 76 Hz |
Horizontal Refresh Rate | 82 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Colour temperature |
Features | HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 51.4 cm x 20 cm x 38.55 cm - with stand |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Audio line-in , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), wall mountable, tilt adjustment |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | Internal |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 25 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 51.41 cm - depth: 4.5 cm - height: 31.5 cm |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7 |
