ASUS VP229 is a 21.5 inch Full HD monitor that features a frameless IPS panel for wide angle viewing to deliver incredibly sharp imagery and stunning video playback. Up to 75Hz refresh rate with Adaptive-Sync/FreeSync technology to eliminate tracing and ensure crisp and clear video playback. TÜV Rheinland-certified Flicker-free and Low Blue Light provides a comfortable viewing experience.
Product Description | ASUS VP229HE - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class F | Power Consumption (On mode) | 19 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.24795 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 49 cm x 19.9 cm x 36.3 cm | Weight | 2.9 kg | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 85 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Adaptive-Sync technology, Colour Temperature Selection, frameless bezel design |
Colour | Black |
Dimensions (WxDxH) | 49 cm x 19.9 cm x 36.3 cm - with stand |
Weight | 2.9 kg |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
Tilt Angle | -5/+23 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19 kWh/1000h |
Power Consumption (Typical) | 12 Watt |
Power Consumption Sleep | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 49 cm - depth: 5.3 cm - height: 29.8 cm - weight: 2.5 kg , With stand - width: 49 cm - depth: 19.9 cm - height: 36.3 cm - weight: 2.9 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 55.2 cm |
Shipping Depth | 13.2 cm |
Shipping Height | 42 cm |
Shipping Weight | 4.2 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
