Delicate touches make a monitor truly great, VS247HR Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Product Description | ASUS VS247HR - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class A | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 22 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.272 mm | Brightness | 250 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Response Time | 2 ms (gray-to-gray) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) | 56.18 cm x 20 cm x 41.06 cm | Weight | 4.2 kg | Environmental Standards | TCO Certified Displays 7, ENERGY STAR Qualified | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, EK, FCC, RoHS, WEEE, J-MOSS, ErP Ready | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Vertical Refresh Rate | 50 - 75 Hz |
Horizontal Refresh Rate | 24 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, input select, colour temperature, aspect control |
Features | sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode |
Colour | Black |
Weight | 4.2 kg |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DVI cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 22.7 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
TCO Certified | TCO Certified Displays 7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
