1ms Quick Response Time Meets Classic Elegant Design
Delicate touches make a monitor truly great, VS248H Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Superior image quality meets classic elegant design
Your eyes are drawn to its unprecedented design--a fusion between the contrasts of gloss black and mat texture. Sleek texture with expressly designed vortex pattern on the pedestal and fingerprint-proof embossment at the back add versatility and the harmonious relationship of a line and circle to the monitor. The metallic stand delivers a sense of avant-garde and cosmopolitan chic. In itself, it is a work of art that accentuates any living space.
True-to-life Pictures Powered by LED
50,000,000:1 ASUS Smart Contrast Ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Full HD 1080p Support
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support.
1ms Response Time
Quick response time of 1ms (GTG) eliminates ghosting and tracers for more fluid video playback.
Aspect Control function
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Versatile viewing positions with Smart View Technology
When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing.
Splendid™ Video Intelligence Technology
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Stylish and User-friendly Design for Modern Sophistication
Convenient key controls for functional set-up in the multi-language OSD.
Easily detachable base for wall mount.
VESA Wall Mount Standard (100 x 100 mm ).
25° ( forward 5°, backwards 20° )Tilting Angle.
KENSINGTON Security Lock
Complete After-Sale Service
3-year system warranty
3-year panel warranty
Free pick-up service (in specific countries)
Green in Mind
Greener Materials
Mercury-free LED-backlit panel
Corrugated cardboard packaging with at least 80% recycled content Slim-flat packaging allows more cartons to be fitted per cargo, reducing transportation costs and CO2 emission
Energy and Planet Saving
37.2k Wh electricity saving
23.6kg reduction in CO2emissions, equivalent to:
1.9 trees planted
2 years of oxygen for a family of four
Product Description | ASUS VS248HR - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class A+ | Energy Consumption per Year | 27 kWh | Power Consumption (On mode) | 19 W | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2768 mm | Brightness | 250 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, DVI-D, VGA | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 57.32 cm x 20.55 cm x 41.23 cm | Weight | 4.1 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, J-MOSS, ErP Ready, CEL level 2 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Controls & Adjustments | Brightness, contrast, input select, colour temperature, aspect control |
Features | HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, Smart View Technology, anti-fingerprint, Slim Design |
Colour | Black |
Dimensions (WxDxH) | 57.32 cm x 20.55 cm x 41.23 cm - with stand |
Weight | 4.1 kg |
Connectivity | |
Interfaces | VGA , DVI-D , HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), wall mountable |
Cables Included | 1 x VGA cable , 1 x DVI cable |
Power | |
Power Consumption Operational | 23.2 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 57.32 cm - depth: 4.57 cm - height: 34.63 cm , With stand - width: 57.32 cm - depth: 20.55 cm - height: 41.23 cm - weight: 4.1 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
