Asus VT168H 15.6" 1366 x 768 Touchscreen HDMI, VGA Monitor
£141.02
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 15.6" 10 point touch capacity, suitable for any application that involves virtual keyboard or multi-touch
  • -5°-30° tilt angle, flexible enough for scenarios as a extend monitor or POS machine
  • Slim Elegant Design with VESA mount (75 mm x 75 mm)
  • Blue light filter & flicker free technology decrease the eye fatigue after long working hrs
  • Diagonal Size: 15.6in
  • Max Resolution: 1366 x 768
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
The ASUS VT168H touchscreen monitor combines 10-point multi-touch capability with superb image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches - is optimized for use with Windows 10, allowing you to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168H has undergone stringent performance tests and is awarded Flicker-free and Low Blue Light certifications by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, toshow display quality with clear image and prevent users suffering from eye strain and fatigue.
Product Description ASUS VT168H - LED monitor - 15.6"
Device Type LED-backlit LCD monitor - 15.6" - touchscreen
Energy Class Class A+
Energy Consumption per Year 12 kWh
Power Consumption (On mode) 8 W
Aspect Ratio 16:9
Native Resolution 1366 x 768
Pixel Pitch 0.252 mm
Brightness 200 cd/m²
Contrast Ratio 50000000:1 (dynamic)
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - with stand 37.78 cm x 18.94 cm x 28.07 cm
Weight 1.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VT168H 15.6" 1366...
£141.02
