The ASUS VT168H touchscreen monitor combines 10-point multi-touch capability with superb image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches - is optimized for use with Windows 10, allowing you to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168H has undergone stringent performance tests and is awarded Flicker-free and Low Blue Light certifications by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, toshow display quality with clear image and prevent users suffering from eye strain and fatigue.
Product Description | ASUS VT168H - LED monitor - 15.6" | Device Type | LED-backlit LCD monitor - 15.6" - touchscreen | Energy Class | Class A+ | Energy Consumption per Year | 12 kWh | Power Consumption (On mode) | 8 W | Aspect Ratio | 16:9 | Native Resolution | 1366 x 768 | Pixel Pitch | 0.252 mm | Brightness | 200 cd/m² | Contrast Ratio | 50000000:1 (dynamic) | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 37.78 cm x 18.94 cm x 28.07 cm | Weight | 1.4 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15.6" |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 90 |
Vertical Viewing Angle | 65 |
Backlight Technology | LED backlight |
Features | HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, glare, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Colour Temperature Selection |
Colour | Black |
Dimensions (WxDxH) | 37.78 cm x 18.94 cm x 28.07 cm - with stand |
Weight | 1.4 kg |
Input | |
Type | Touchscreen |
Connectivity | |
Interfaces | VGA , HDMI , Micro-USB |
Mechanical | |
Tilt Angle | -5/+30 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x micro-USB cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 7 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 33.78 cm - depth: 4.4 cm - height: 23.59 cm , With stand - width: 37.78 cm - depth: 18.94 cm - height: 28.07 cm - weight: 1.4 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 43.38 cm |
Shipping Depth | 12.2 cm |
Shipping Height | 34.97 cm |
Shipping Weight | 2.8 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
