Asus VT168N 15.6" 10-point Capacitive Multi-Touch Monitor
£135.44
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 15.6" 10 point touch capacity, suitable for any application that involves virtual keyboard or multi-touch
  • -5 ° ~30 ° tilt angle, flexible enough for scenarios as a extend monitor or POS machine
  • Slim elegant design with VESA mount
  • Blue light filter & flicker free technology decrease the eye fatigue after long working hrs
Product codes
The ASUS VT168N touchscreen monitor combines 10-point multi-touch capability with amazing image quality, flexible connectivity and great ergonomics. The precise and accurate multi-touch display - allowing up to 10 simultaneous touches to work smarter and more efficiently.
ASUS Splendid Video Intelligence technology employs a color engine with six preset modes. These allow you to adjust your display easily for the best color accuracy and image fidelity, depending on what kind of content is being displayed. You can access the presets via a designated hotkey.
VT168N has multiple video and peripheral connectors, including VGA and DVI-D, making it suitable for use anywhere, either in the home or at the office. VT168N features an elegant circular base with an ergonomically-designed tilting stand that lets you choose the ideal viewing position. The monitor is also VESA mount-compatible, making it easy to mount on a wall or monitor arm.
ASUS Eye Care monitor provides eye care features - Flicker free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment.
Product Description ASUS VT168N - LED monitor - 15.6"
Device Type LED-backlit LCD monitor - 15.6" - touchscreen
Aspect Ratio 16:9
Native Resolution 1366 x 768
Pixel Pitch 0.252 mm
Brightness 200 cd/m²
Contrast Ratio 600:1 / 50000000:1 (dynamic)
Response Time 10 ms
Colour Support 262,144 colours
Input Connectors DVI-D, VGA
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - without stand 33.78 cm x 4.4 cm x 23.59 cm
Weight 1.4 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV GS, VCCI, C-Tick, BSMI, WHQL, CB, TUV Ergo, PSB, RoHS, KCC, WEEE, TCO '06, MEPS, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VT168N 15.6" 10-p...
£135.44
