Asus VX24AH 23.8" 2560x1440 5ms VGA HDMI IPS Monitor
£248.92
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • See better and wider
  • Made for work and play
  • Extensive connectivity
  • QuickFit Virtual Scale for true what you see is what you get
  • ASUS SplendidPlus Video Intelligence technology
  • ASUS EyeCare technology
  • Diagonal Size: 23.8in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £252.41
Save £1.50
Envision bigger with WQHD! Premium wide-format VX24AH LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive SplendidPlus Video Intelligence technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. Dual HDMI support WQHD natively, accentuated by room-dominating audio via twin speakers.
Product Description ASUS VX24AH - LED monitor - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 25 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440
Pixel Pitch 0.206 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, VGA
Speakers Integrated
Display Position Adjustments Tilt
Colour Black
Dimensions (WxDxH) - with stand 54.05 cm x 21.01 cm x 39.44 cm
Weight 3.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, J-MOSS, ErP Ready, ISO9241-307
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VX24AH 23.8" 2560...
£248.92
