A stunning addition to any desk with its gorgeous ultra-slim 24" Full HD IPS display, the ASUS VZ249HE delivers vibrant colors with 178° viewing angle over HDMI/VGA. Built-in ASUS Eye Care technology actively reduces eye strain for prolonged viewing, while the frameless design delivers panoramic viewing immersion for multi-display setups.
Product Description | ASUS VZ249HE - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Energy Consumption per Year | 33 kWh | Power Consumption (On mode) | 16.3 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2652 mm | Brightness | 250 cd/m² | Contrast Ratio | 80000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54 cm x 21.1 cm x 39.1 cm | Weight | 2.9 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, ERP, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 56 - 76 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Ultra Slim Design, HDCP, frameless, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Wide Viewing Angle, Colour Temperature Selection, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 54 cm x 21.1 cm x 39.1 cm - with stand |
Weight | 2.9 kg |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
Tilt Angle | -5/+22 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.3 kWh/1000h |
Power Consumption (Typical) | 14.75 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 54 cm - depth: 3.7 cm - height: 32.3 cm , With stand - width: 54 cm - depth: 21.1 cm - height: 39.1 cm - weight: 2.9 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - LCD panel - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
