Asus VZ279Q 27" 1920x1080 IPS Monitor DP HDMI D-Sub
£219.93
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ultra-slim profile
  • Perfect for multi-display setups
  • Protect your eyes with ASUS Eye Care technology
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The ASUS VZ279Q has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for multi-display setups that give you an even greater degree of immersion.
Product Description ASUS VZ279Q - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 25 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.311 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 62.1 cm x 21 cm x 43.95 cm
Weight 3.9 kg
Environmental Standards TCO Certified ENERGY STAR Qualified
Compliant Standards UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, CU, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VZ279Q 27" 1920x1...
£219.93
