ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
Product Description | ASUS VZ27AQ - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class A | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 24 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 | Pixel Pitch | 0.233 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 80000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 1.074 billion colours (10-bit) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Colour | Black, icicle gold | Dimensions (WxDxH) - with stand | 61.27 cm x 21 cm x 44.08 cm | Weight | 4.26 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Panel Type | IPS |
Vertical Refresh Rate | 49 - 76 Hz |
Horizontal Refresh Rate | 29 - 130 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Ultra Slim Design, HDCP, frameless, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 100% sRGB colour gamut, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection |
Dimensions (WxDxH) | 61.27 cm x 21 cm x 44.08 cm - with stand |
Weight | 4.26 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 1.5 Watt |
Connectivity | |
Interfaces | VGA , HDMI , DisplayPort , Audio line-in |
Mechanical | |
Tilt Angle | -5/+22 |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x audio cable |
Power | |
Power Consumption (Off Mode) | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 61.27 cm - depth: 3.655 cm - height: 36.82 cm , With stand - width: 61.27 cm - depth: 21 cm - height: 44.08 cm - weight: 4.26 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 68.9 cm |
Shipping Depth | 11.7 cm |
Shipping Height | 54.4 cm |
Shipping Weight | 5.295 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
