Asus VZ27AQ 27" 2560x1440 IPS Monitor
£323.92
Delivery:
Standard: 1-3 working days
Key features
  • Ultra-slim profile
  • See better with WQHD resolution
  • Perfect for multi-display setups
  • Ultra-low Blue Light monitor
  • Flicker-Free technology
  • Wide 178° viewing angles
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
ASUS VZ27AQ has a space-saving design with an ultra-slim profile. Its frameless design makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion. An advanced high-performance IPS panel gives you an astonishing 80,000,000:1 contrast ratio and wide 178° viewing angles. In addition, ASUS Eye Care technology ensures a comfortable viewing experience.
Product Description ASUS VZ27AQ - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 35 kWh
Power Consumption (On mode) 24 W
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440
Pixel Pitch 0.233 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.074 billion colours (10-bit)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Tilt
Screen Coating Anti-glare
Colour Black, icicle gold
Dimensions (WxDxH) - with stand 61.27 cm x 21 cm x 44.08 cm
Weight 4.26 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus VZ27AQ 27" 2560x1...
£323.92
