Asus Zenbook 14" Core i7-7500U 8GB 256GB SSD Windows 10...
£839.00
Delivery:
Key features
  • Ultra-sleek and ultra-elegant
  • Big and clear display
  • ASUS Splendid: superbly optimized color
  • Ultra connectivity
  • Outstandingly comfortable backlit keyboard
  • ASUS SonicMaster: designed to sound incredible
  • Display Size: 14in
  • Processor Model: I7-7500U
  • Operating System: Windows 10 Home 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 256GB
Product codes
The all-new ZenBook UX410 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring our iconic spun-metal Zen-inspired finish, ZenBook UX410 is a mere 18.95mm thin. And its travel-friendly weight of just 1.4kg means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear 14-inch wide viewing angle display and 6mm slim bezel. ZenBook UX410 makes everything easier, in style.
Ultra Sleek. Ultra Elegant
The ZenBook Series practically invented thin and light, and ZenBook UX410 continues that proud heritage, featuring a timelessly elegant all-new design with a profile that's just 18.95mm thin. Using solid aluminum alloy keeps the weight down to just 1.4kg, but it takes dozens of precisely-controlled manufacturing steps to craft it into its sleek shape. Our unique spun-metal finish, with its Zen-inspired concentric circles, adorns the lid, with a tough and durable brushed-metal finish adorning the rest of the chassis. Finally, we anodize ZenBook UX410 in one of two nature-inspired shades: Quartz Grey or Rose Gold.
Incredible Performance
Superb mobile performance is the hallmark of ZenBook, and in ZenBook UX410 this is delivered by an Intel® Core™ i7 Processor, 8GB RAM. The latest dual-band 802.11ac Wi-Fi provides super-fast speeds, and Bluetooth® 4.1 connects you easily to your gadgets. True professionals demand the latest technology, and the revolutionary, reversible USB Type-C port gives you high-speed access to the latest high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches — ZenBook UX410 is always ready when you are. It's supremely energy-efficient too, meaning fewer trips to the power socket!
Product Description ASUS ZenBook UX410UA GV183T - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD
Product Type Notebook
Operating System Win 10 Home 64-bit
Processor Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
Memory 8 GB DDR4 (provided memory is soldered)
Storage 256 GB SSD
Optical Drive No optical drive
Display 14" LED backlight 1920 x 1080 / Full HD
Graphics Intel HD Graphics 620
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11ac, Bluetooth 4.1, Ethernet
Battery 3-cell
Colour Quartz grey
Dimensions (WxDxH) 32.3 cm x 22.3 cm x 1.895 cm
Weight 1.4 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Repaired under warranty. Good condition
Ref: F8ZL 041183
£571.92
product
Ref: F8ZL 041183
Accessories
Packaging
Functional
Software
Manuals
£571.92
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus Zenbook 14" Core...
£839.00
