The all-new ZenBook UX410 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring our iconic spun-metal Zen-inspired finish, ZenBook UX410 is a mere 18.95mm thin. And its travel-friendly weight of just 1.4kg means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear 14-inch wide viewing angle display and 6mm slim bezel. ZenBook UX410 makes everything easier, in style.
Ultra Sleek. Ultra Elegant
The ZenBook Series practically invented thin and light, and ZenBook UX410 continues that proud heritage, featuring a timelessly elegant all-new design with a profile that's just 18.95mm thin. Using solid aluminum alloy keeps the weight down to just 1.4kg, but it takes dozens of precisely-controlled manufacturing steps to craft it into its sleek shape. Our unique spun-metal finish, with its Zen-inspired concentric circles, adorns the lid, with a tough and durable brushed-metal finish adorning the rest of the chassis. Finally, we anodize ZenBook UX410 in one of two nature-inspired shades: Quartz Grey or Rose Gold.
Incredible Performance
Superb mobile performance is the hallmark of ZenBook, and in ZenBook UX410 this is delivered by an Intel® Core™ i7 Processor, 8GB RAM. The latest dual-band 802.11ac Wi-Fi provides super-fast speeds, and Bluetooth® 4.1 connects you easily to your gadgets. True professionals demand the latest technology, and the revolutionary, reversible USB Type-C port gives you high-speed access to the latest high-performance peripherals. With the HDMI port, you can connect to monitors, TVs or projectors with no hassle. Effortless multitasking, smooth video playback, and super-fast application launches — ZenBook UX410 is always ready when you are. It's supremely energy-efficient too, meaning fewer trips to the power socket!
Product Description | ASUS ZenBook UX410UA GV183T - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 256 GB SSD | Optical Drive | No optical drive | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11ac, Bluetooth 4.1, Ethernet | Battery | 3-cell | Colour | Quartz grey | Dimensions (WxDxH) | 32.3 cm x 22.3 cm x 1.895 cm | Weight | 1.4 kg |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7500U / 2.7 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0, Intel Anti-Theft Technology |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD - (M.2) SATA 6Gb/s |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | ASUS Splendid Video Intelligence Technology, anti-glare, 72% NTSC colour gamut, ASUS EyeCare Technology, 178° horizontal and vertical viewing angle, NanoEdge display |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - HD |
Sound | Stereo speakers, microphone |
Audio Features | ASUS SonicMaster |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11ac, Bluetooth 4.1 |
Network Interface | Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces | 2 x USB 2.0 , HDMI , USB 3.0 , Headphone/microphone combo jack , USB-C 3.1 Gen 1 , LAN (on supplied adapter) , VGA (on supplied cable) |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card) |
Miscellaneous | |
Features | System password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter, sleeve, USB to Ethernet adapter |
Cables Included | HDMI-VGA cable |
Dimensions & Weight | |
Weight | 1.4 kg |
Repaired under warranty. Good condition
Ref: F8ZL 041183 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£571.92
