Asus Zenbook UX433FA Core i7-8565 8GB 512GB 14" Windows...
Asus Zenbook UX433FA Core i7-8565 8GB 512GB 14" Windows 10 Home - Royal Blue
£849.00
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Compact design
  • Unbounded beauty
  • Spectacular visuals
  • Designed with you in mind
  • Mobility without bounds
  • All-day battery for non-stop lifestyles
  • Display Size: 14in
  • Processor Model: I7-8565U
  • Operating System: Windows 10 Home
  • Installed Memory: 8GB
  • Hard Drive Capacity: 512GB
Product codes
Unleash your creative vision
The world’s smallest 14-inch laptop
Creativity. Style. Innovation. These are the qualities that define the elegant new ZenBook 14. Everything in this take-anywhere masterpiece — it’s the world’s smallest 14-inch laptops* — is designed to give you the freedom to discover your creative power, including its breathtaking frameless NanoEdge display. You’ll appreciate not only the tremendous power within and the thoughtful attention to detail — such as the exclusive ErgoLift hinge and NumberPad touchpad — but also the timeless beauty of the design, with its sensational Royal Blue or Icicle Silver finish enhanced by the new Rose Gold trim panel. ZenBook 14 is waiting: are you ready to unleash your creative power?
The most compact design ever
ZenBook 14 heralds a new era of ultraportable design, with an ultracompact, ultralight chassis. Featuring the 4-sided NanoEdge display, the ZenBook 14 is one of the world’s most smallest 14-inch laptop and is 13% smaller than the previous generation ZenBook 14 (UX430).
NanoEdge Display
Designed to give you the most screen area in the least physical space, the new frameless four-sided NanoEdge design of ZenBook 14 is simply breathtaking: it makes any visuals more immersive, with less distraction for your eyes. The ultraslim bezels1 are just 2.9mm thin at the sides, 3.3mm at the bottom and a mere 6.1mm at the top to accommodate the camera. The effect is truly stunning — it’s like an infinity pool for your eyes! And with this ultra-compact display, ZenBook 14 is only about the size of an A4 sheets — smaller than many 13.3-inch laptops.
Spectacular visuals
Creativity demands a great screen, so ZenBook 14 has a crisp, clear, high-resolution display that makes any visuals look their best, with wide viewing angles and vivid, accurate colours. It also features exclusive ASUS technologies — including ASUS Splendid and ASUS Tru2Life Video — that fine-tune display parameters to ensure optimum eye comfort and colour performance, for any kind of content.
With any ZenBook, your comfort is one of our top priorities. ZenBook 14 goes the extra mile with its exclusive ErgoLift hinge, an engineering masterpiece designed to automatically tilt the keyboard to the most comfortable typing position. But that’s not all: the carefully calculated tilt improves cooling and audio performance, too.
Extraordinary elegance
None of the traditional ZenBook style has been lost, though: there’s the iconic Zen-inspired spun-metal finish on the lid and a choice of prestigious Royal Blue or sophisticated Icicle Silver finishes, both newly enhanced with a contrasting Rose Gold trim panel above the keyboard for an extra touch of luxury. The elegant Royal Blue colour is inspired by the awesome beauty of a golden sunrise over the deep-blue ocean. The sophisticated Icicle Silver reflects the stunning contrasts of native gold and moonlight silver, a harmonious pairing celebrated in this classic theme.
Unbounded performance
Designed to empower your creativity, ZenBook 14 doesn’t sacrifice performance for size. It’s built to give you all the raw power you need for effortless on-the-go computing. Featuring the latest Intel® Core™ processors and packed with high-quality, high-performance components, ZenBook 14 will never keep you waiting. Whether you’re creating complex documents, mining data, retouching photos, editing videos, or simply taking a gaming break, ZenBook 14 lets you do more — and do it quicker.
Product Description ASUS ZenBook 14 UX433FA A5128T - 14" - Core i7 8565U - 8 GB RAM - 512 GB SSD
Product Type Notebook
Operating System Windows 10 Home
Processor Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
Memory 8 GB LPDDR3 (provided memory is soldered)
Storage 512 GB - M.2 SSD NVMe
Optical Drive No optical drive
Display 14" LED backlight 1920 x 1080 / Full HD
Graphics Intel UHD Graphics 620
Input Device NumberPad
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11ac, Bluetooth 5.0
Battery 3-cell
Colour Royal blue
Dimensions (WxDxH) 31.9 cm x 19.9 cm x 1.59 cm
Weight 1.19 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus Zenbook UX433FA C...
£849.00
