Asus ZenFone 4 Max 32GB 4G LTE GSM 5.5" dual-SIM - Rose...
FREE DELIVERY
FREE BUNDLE
LIMITED TIME OFFER
Asus ZenFone 4 Max 32GB 4G LTE GSM 5.5" dual-SIM - Rose Pink
SEE BUNDLE DEALS FOR FREE 32GB MICROSD!
Colours:
Key features
  • Dual rear cameras
  • Wide-angle camera
  • PixelMaster camera
  • Capture the perfect selfie
  • Beauty mode
  • A smarter smartphone battery
  • High capacity, 5000mAh battery
  • Fast, multi-threaded performance
  • Dual SIM with individual microSD card slot
  • Android 7 with brand new ZenUI
Product codes
120° Wide View Dual Rear Cameras, 5000mAh Battery
ASUS ZenFone 4 Max is a smartphone designed to go the distance and accompany you on all of life’s adventures. Its high capacity 5000mAh battery with advanced power management and dual cameras keeps up with your active lifestyle and is always at the ready to capture extraordinary moments.
Dual Rear Cameras - See a bigger world
ZenFone 4 Max features an advanced dual-camera system designed to take your mobile photography to new heights. Its 13MP main camera is equipped with the wide, F2.0 aperture lens to capture clearer photos. Its 120° wide-angle camera lets your fit more scenery and people in the frame for dramatic landscape shots, better group photos, and a more convenient photography experience in confined indoor spaces.
Wide-Angle Camera - Fit more scenery and friends in the shot
The 120° wide-angle camera on ZenFone 4 Max has a 200% larger field of view than standard smartphone cameras, so you can fit more scenery and people in the frame for dramatic photos and videos that capture a true sense of place. When taking photos indoors, the wide-angle view makes it much easier to get the shot you want — especially in confined spaces where it may not be possible to take a few steps back to fit everyone and everything into the photo. The unique perspective of the wide-angle lens can also be used to stylistic effect, allowing you to exaggerate the sense of space in any setting to capture more dramatic scenes and stunning, expansive landscapes.
PixelMaster Camera - Capture your world in detail
ZenFone 4 Max comes with a 13MP PixelMaster rear camera to capture beautiful, high-resolution photos with zero shutter lag. An 8MP front camera takes gorgeous, sharp selfies and lets you enjoy video chatting in with crystal-clear video clarity.
Front Camera - Capture the perfect selfie
ZenFone 4 Max combines an 8MP front camera with a Softlight LED flash and live beautification features to capture stunning selfies with ease. The Softlight LED flash delivers the perfect amount of fill light, giving your selfies a softer look with true skin tones and a glowing complexion. Beauty mode instantly retouches your selfies, removing blemishes, balancing facial features, and more to create a flawless look.
Beauty Mode - More beautiful, more fun, more you
The fun and intuitive Beauty mode lets you apply a variety of enhancement effects to your selfies to make them even more glamorous. With ten levels of beautification to choose from, you can smooth wrinkles, remove blemishes, adjust skin tone, and enhance your features instantly. Whether you are taking photos, capturing a video, or live streaming, ZenFone 4 Max lets you create your perfect look for the camera.
ASUS PowerMaster™ - A smarter smartphone battery
ZenFone 4 Max features a suite of intelligent power management technologies that work in concert to optimize battery life, ensure safety and long-term performance, provide reverse-charging capability, and more. By turning on the double battery lifespan feature, it means your device can fully charge (to 100%) and discharge (to 0%) up to 500 times in a 25°C environment, and the loss of battery capacity will be reduced by half.
  • This feature "double battery lifespan" effectiveness may vary depending on your usage.
Inside the sleek exterior of ZenFone 4 Max lies massive energy — a 5000mAh battery custom-crafted to pack maximum performance into minimum space. With so much power at your disposal, you can do more online, stream longer videos, and talk as much as you want without worry of getting through the day.
  • Standby time measured by current meter with typical battery capacity. Results may vary depending on different test conditions.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
Product Description ASUS ZenFone 4 Max (ZC554KL) - rose pink - 4G LTE - 32 GB - GSM - smartphone
Product Type Smartphone 4G
Manufacturer Model Number ZC554KL
Display LCD display - 1280 x 720 pixels - 5.5" - IPS
Features Front-facing camera, FM radio, dual rear-facing camera
Processor Qualcomm Snapdragon 430 MSM8937 / 1.4 GHz (8-core) - 64-bit
Graphics Accelerator Qualcomm ADRENO 505
Memory 32 GB - RAM 3 GB + microSDHC, microSDXC slot - up to 256 GB
Operating System Android 7.1.1 Nougat with ASUS ZenUI
Rear Camera 13 Megapixel - f/2.0 - focus: automatic laser auto focus: - laser focus
Second Rear Camera 5 Megapixel - wide-angle lens
Front Camera 8 Megapixel - wide-angle lens - f/2.2
Service Provider Not specified
SIM Card Type Nano SIM
SIM Card Slot Qty Dual-SIM
Wireless Interface Wi-Fi, Bluetooth
Security Devices Fingerprint reader
Messaging Services SMS, MMS
Connectors 3.5 mm headset jack, Micro-USB
Talk Time Up to 2400 minutes
Standby Time Up to 1104 hours
Colour Rose pink
Dimensions (WxDxH) 76.9 mm x 8.9 mm x 154 mm
Weight 181 g
SAR 1.2 W/kg (body) / 0.302 W/kg (head)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus ZenFone 4 Max 32G...
