Asus ZenScreen MB16AC 15.6" 1920 x 1080 USB C Portable M...
£255.56
Delivery:
Key features
  • Hybrid-signal solution - USB Type A and Type C support
  • Slim and stylish ultra-portable design
  • Automatic screen orientation
  • Wide viewing angles
  • ASUS blue light filter
  • ASUS Flicker-free technology
Product codes
ASUS ZenScreen MB16AC 15.6 inch FHD IPS USB Type-C Portable Eye Care Monitor
  • 15.6" FHD IPS USB Type-C portable monitor with hybrid signal solution for compatibility with USB Type-C and Type-A sources (Note: DisplayLink driver needed for Type-A connection)
  • Ultra-portable award-winning design at 1.7 pounds and 0.3 inches slim to pair perfectly with ASUS laptops
  • Smart cover and smart pen hole allow for landscape and portrait orientations easily with auto rotation
  • ASUS Eye Care technology with TUV Rheinland-certified flicker-free backlighting and blue light filter minimizes eye fatigue
  • Easily toggle through advanced display settings with the intuitive ASUS DisplayWidget
Product Description ASUS ZenScreen MB16AC - LED monitor - Full HD (1080p) - 15.6"
Device Type LED-backlit LCD monitor - 15.6"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.179 mm
Brightness 220 cd/m²
Contrast Ratio 800:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 262,000 colours
Input Connectors USB
Colour Dark grey
Dimensions (WxDxH) 35.97 cm x 0.8 cm x 22.64 cm
Weight 780 g
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, UkrSEPRO, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus ZenScreen MB16AC...
£255.56
