ASUS ZenScreen MB16AC 15.6 inch FHD IPS USB Type-C Portable Eye Care Monitor
Product Description | ASUS ZenScreen MB16AC - LED monitor - Full HD (1080p) - 15.6" | Device Type | LED-backlit LCD monitor - 15.6" | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.179 mm | Brightness | 220 cd/m² | Contrast Ratio | 800:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 262,000 colours | Input Connectors | USB | Colour | Dark grey | Dimensions (WxDxH) | 35.97 cm x 0.8 cm x 22.64 cm | Weight | 780 g | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, UkrSEPRO, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 15.6" |
Panel Type | IPS |
Vertical Refresh Rate | 60 Hz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Features | Glare, ASUS Splendid Video Preset Mode, 45% NTSC colour gamut, ASUS QuickFit Virtual Scale, ASUS GamePlus, Slim Design, Low Blue Light Mode, auto-rotation, Blue Light Filter technology |
Weight | 780 g |
Connectivity | |
Interfaces | USB-C |
Miscellaneous | |
Features | Flicker-free technology |
Included Accessories | Carrying case with display stand |
Cables Included | 1 x USB-C cable , 1 x USB-C to USB-A adapter |
Power | |
Power Consumption Operational | 8 Watt |
Power Consumption (Off Mode) | 0 Watt |
Software / System Requirements | |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Dimensions & Weight (Shipping) | |
Shipping Width | 42.4 cm |
Shipping Depth | 7.6 cm |
Shipping Height | 31 cm |
Shipping Weight | 3 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
