Ballistix 2GB DDR2 800MHZ (PC2-6400) CL5
£27.09
Delivery:
Product codes
The Crucial Ballistix Sport Series is designed for mainstream users and general enthusiasts. A simple, slick heat spreader delivers thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility. With industry-standard specifications, little or no BIOS configuration is required. That means this product installs easily, so you can get up and going / gaming quickly. Available in both DDR2 and DDR3 in the most common and popular speeds and densities, you'll be sure to find a product that suits your needs.
Ballistix Sport - DDR2 - 2 GB - DIMM 240-pin - unbuffered
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5
Aluminium heat spreader, unbuffered
Voltage
1.8 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Ballistix 2GB DDR2 800...
£27.09
