Ballistix 4GB DDR3 1600 MT/s (PC3-12800) CL8 @1.5V Tactical T...
Ballistix 4GB DDR3 1600 MT/s (PC3-12800) CL8 @1.5V Tactical Tracer UDIMM 240pin
£36.44
Delivery:
Key features
  • On-the-fly customizable
  • LED activity colors, patterns
  • Uptime monitor
  • Thermal sensor allows real-time temperature monitoring
  • Voltage monitor and history
  • Temperature monitor and history
  • Premium-quality DRAM
  • Proven stability and reliability
Product codes
Crucial Ballistix Smart Tracer memory starts with everything you love about the Ballistix Tracer: activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom. And then Crucial has added more!
The Ballistix Smart Tracer is all about customization. Using Crucial's custom programmed Ballistix Memory Overview Display (MOD) utility, you can manipulate the dual-color LEDs in real time and switch the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on the fly!
Features in the Crucial Ballistix MOD utility also allow you to view uptime, voltages, and set alarms for temperatures. That makes it one of the most customizable, responsive modules you'll find. In addition to the LED light controls, this tool lets you enjoy real-time temperature monitoring and keep tabs on your high-performance memory while you play.
Product Description Ballistix Smart Tracer - DDR3 - 4 GB - DIMM 240-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR3 SDRAM - DIMM 240-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 1600 MHz (PC3-12800)
Latency Timings CL8 (8-8-8-24)
Features Heat sink, temperature monitoring, Red/Green activity LED's, unbuffered
Voltage 1.5 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ballistix 4GB DDR3 160...
£36.44
