Ballistix Crucial 8GB DDR3 CL9 @1.5V Ballistix Sport XT UDIM...
Ballistix Crucial 8GB DDR3  CL9 @1.5V Ballistix Sport XT UDIMM 240pin
Key features
  • Performance memory for gamers and enthusiasts
  • XMP profile for advanced speeds and timings
  • Tall, aggressive heat spreader
  • Premium - quality DRAM
  • Easy to install
Product codes
Designed for gamers who are comfortable changing BIOS settings to unleash their memory's full potential, Sport XT modules offer blazing - fast DDR3 speeds up to 1866 MHz. With an expanded heat spreader that offers more surface area for heat dissipation, Sport XT modules enable better thermal performance. Coupled with an aggressive design and XMP profiles for easy configuration in Intel - supported systems, Sport XT modules deliver no-hassle performance so you can own your opponents.
Engineered to deliver fast and reliable performance memory for enthusiasts and mainstream users alike, the Crucial Ballistix Sport series is a great place to start. Touting all the usual benefits of a memory upgrade - faster load times, better system responsiveness, and increased ability to handle data-intensive games - Ballistix Sport modules also feature an array of additional features. With an eye-catching design, premium-quality DRAM, and a stylish integrated heat spreader for thermal performance, Ballistix Sport makes it easy to take your game to the next level. Since Ballistix Sport performance memory is budget-friendly and compatible with nearly every type of system, you'll be hard pressed to find a better win.
Ballistix Sport XT - DDR3 - 8 GB - DIMM 240-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Aluminium heat spreader, Intel Extreme Memory Profiles (XMP), unbuffered
Voltage
1.5 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Ballistix Crucial 8GB...
