Ballistix Elite 16GB (4GBx4) DDR3 2133 MT/s (PC3-17000) CL11...
Ballistix Elite 16GB (4GBx4) DDR3 2133 MT/s (PC3-17000) CL11 @1.65V UDIMM w/XMP/TS 240pin
£160.45
Delivery:
Key features
  • Advanced finned integrated heat spreader
  • Advanced speeds and timings
  • Thermal sensor allows real-time temperature monitoring
  • Custom Ballistix M.O.D. utility - temperature monitor and history
  • Premium-quality DRAM
  • Proven stability and reliability
Product codes
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Ballistix Elite - DDR3 - 16 GB: 4 x 4 GB - DIMM 240-pin - unbuffered
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-11-11-27)
Temperature monitoring, Intel Extreme Memory Profiles (XMP), Advanced finned Integrated heatspreader, Black PCB, unbuffered
Voltage
1.65 V
Limited lifetime warranty (Germany - 10 years)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ballistix Elite 16GB (...
£160.45
