Ballistix Elite 4GB DDR4 3000 MT/s (PC4-24000) CL15 SR x8 Unb...
Ballistix Elite 4GB DDR4 3000 MT/s (PC4-24000) CL15 SR x8 Unbuffered DIMM 288pin
£38.56
Delivery:
Key features
  • Advanced finned integrated heat spreader
  • Advanced speeds and timings
  • Thermal sensor allows real-time temperature monitoring
  • Custom Ballistix M.O.D. utility - temperature monitor and history
  • Premium-quality DRAM
  • Proven stability and reliability
  • Type: DDR4 SDRAM
  • Capacity: 4GB
  • Connection: DIMM 288-pin
  • Speed: 3000MHz
  • Data Integrity: Non-ECC
Product codes
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Product Description Ballistix Elite - DDR4 - 4 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 4 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 3000 MHz (PC4-24000)
Latency Timings CL16 (16-16-16)
Features Temperature monitoring, black heatsink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage 1.35 V
Manufacturer Warranty Limited lifetime warranty (Germany - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ballistix Elite 4GB DD...
£38.56
