Ballistix Elite 8GB (4GBx2) DDR4 3000 MT/s (PC4-24000) CL15 S...
Ballistix Elite 8GB (4GBx2) DDR4 3000 MT/s (PC4-24000) CL15 SR x8 Unbuffered DIMM 288pin
Key features
  • Advanced finned integrated heat spreader
  • Advanced speeds and timings
  • Thermal sensor allows real-time temperature monitoring
  • Custom Ballistix M.O.D. utility - temperature monitor and history
  • Premium-quality DRAM
  • Proven stability and reliability
Product codes
The Crucial Ballistix Elite series holds nothing back. Designed for extreme enthusiasts, demanding gamers, and uber-power users, the Ballistix Elite module features the best technical features available in an eye-catching design.
Ballistix Elite - DDR4 - 8 GB: 2 x 4 GB - DIMM 288-pin - unbuffered
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL15 (15-16-16)
Temperature monitoring, black heatsink, Black PCB, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.35 V
Limited lifetime warranty (Germany - 10 years)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Ballistix Elite 8GB (4...
