Ballistix Tactical 16GB (8GBx2) DDR4 3000 MT/s (PC4-24000) CL...
Ballistix Tactical 16GB (8GBx2) DDR4 3000 MT/s (PC4-24000) CL15 DR x8 Unbuffered DIMM 288pin
Key features
  • Designed for performance enthusiasts, gamers and power users
  • Enhanced heat spreader
  • Advanced speeds and timings
  • Premium quality DRAM
  • Proven stability and reliability
Product codes
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Product Description Ballistix Tactical - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin - unbuffered
Product Type RAM memory
Capacity 16 GB: 2 x 8 GB
Memory Type DDR4 SDRAM - DIMM 288-pin
Upgrade Type Generic
Data Integrity Check Non-ECC
Speed 3000 MHz (PC4-24000)
Latency Timings CL15 (15-16-16)
Features Black PCB, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader, unbuffered
Voltage 1.35 V
Manufacturer Warranty Limited lifetime warranty (Germany - 10 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Ballistix Tactical 16G...
