Ballistix Tectical 4GB DDR4 3000 MT/s (PC4-24000) CL15 SR x8...
Ballistix Tectical 4GB DDR4 3000 MT/s (PC4-24000) CL15 SR x8 Unbuffered DIMM 288pin
£27.21
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Designed for performance enthusiasts, gamers and power users
  • Enhanced heat spreader
  • Advanced speeds and timings
  • Premium quality DRAM
  • Proven stability and reliability
Product codes
If you're serious about gaming, we're serious about you. The Crucial Ballistix Tactical Series delivers the latest features at a price you can afford. If you want solid performance, stability, and compatibility, put the Ballistix Tactical series to work for you.
The Crucial Ballistix Tactical Series is designed for performance enthusiasts, gamers and power users. Ballistix Tactical features increased speeds and timings, and enhanced heat spreader for improved thermal performance. If you are looking for reliable, quality memory ideal for stability and compatibility while kicking up the performance factor, the Ballistix Tactical Series is a perfect fit.
Ballistix Tactical - DDR4 - 4 GB - DIMM 288-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL16
Black PCB, Intel Extreme Memory Profiles (XMP 2.0), gunmetal grey heat spreader, unbuffered
Voltage
1.35 V
Limited lifetime warranty (Germany - 10 years)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Ballistix Tectical 4GB...
£27.21
