Beats Fit Pro is equipped with comfortable, secure-fit wingtips that flex to fit your ear. The universal wingtip design was put to the ultimate test by athletes of all kinds so you can trust these earbuds will stay put through work days and workouts. Complete with pressure relieving vents, you can comfortably wear these earbuds all day long.
Three soft silicone eartip options make it easy to find the right size. The Fit Test setup for both Apple and Android helps ensure proper fit for a customized acoustic seal and optimal performance.
Product Description | Beats Fit Pro - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Compatibility | iPhone, iPad, iPod, Android phone, Mac, Android tablet | Recommended Use | Portable electronics | Additional Functions | Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking | Colour | Black beats | Headphones Form Factor | In-ear | Wireless Technology | Bluetooth | Sound Output Mode | Stereo | Active Noise Canceling | Yes | Microphone Operation Mode | Beamforming | Controls | Programmable button | Intelligent Assistant | Siri | Designed For | 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 4; 5; iPhone 11, 12, 13, 6s, 7, 8, SE, X, XR, XS, XS Max; Mac Studio; MacBook Air; MacBook Pro; TV |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Dimensions & Weight Details | Charging case: 6.2 cm x 6.2 cm x 2.85 cm / 55.1 g |
Width | 2.4 cm |
Depth | 3 cm |
Height | 1.9 cm |
Weight | 5.6 g |
Protection | Sweat-resistant, IPX4, water-resistant |
Audio Output | |
Connectivity Technology | Wireless |
Active Noise Cancelling Technology | Adaptive Active Noise Cancellation |
Features | Apple H1 chip, Fit Test |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Tracking | |
Sensors | Accelerometer, gyroscope |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Miscellaneous | |
Included Accessories | 3 pairs of silicone ear tips, charging case, USB-C to USB-C charging cable |
Cable Details | USB-C to USB-C cable |
Compliant Standards | Bluetooth Class 1 |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Run Time (Up To) | 7 hour(s) |
Run Time Details | Continuous playback (noise cancelling OFF): up to 7 hours , Continuous playback (noise cancelling ON): up to 6 hours , Continuous playback (noise cancelling ON / with included charging case): up to 24 hours |
Compatibility Information | |
Designed For | Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Late 2014, Late 2015, Mid 2015, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini (6th generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), SE (3rd generation), X, XR, XS, XS Max , Apple iPod touch (7G) , Apple Mac mini (Early 2020, Late 2014, Late 2018, Late 2020) , Apple Mac Pro (Late 2013, Late 2019) , Apple Mac Studio (Early 2022) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2015, Early 2020, Late 2018, Late 2020, Mid 2017, Mid 2019, Mid 2022) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2017, Mid 2018, Mid 2019, Mid 2022) , Apple TV (1st generation, 2nd generation) , Apple Watch |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
