Beats Solo Pro Wireless Noise Cancelling Headphones - Black
FREE DELIVERY
£269.95
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Active Noise Canceling (ANC) blocks external noise
  • Beats' Pure ANC adapts to external noise and fit while preserving audio quality
  • Transparency helps you stay aware of your surroundings while listening
  • Advanced acoustic system delivers powerful sound with balanced tonality
  • Auto On/Off when you unfold and fold your headphones
  • Ergonomically designed for optimal comfort and extended wear
  • Accessory Type: Headphones
  • Connectivity: Wireless
  • Colour: Black
  • Stock Status: In Stock
Product codes
Get inspired with Solo Pro wireless headphones. To deliver sound how you want it, Solo Pro features two listening modes: Active Noise Canceling (ANC) and Transparency. Beats' Pure ANC gives you the space to create with fully immersive sound, while Transparency helps you stay aware of your surroundings. Every detail of Solo Pro has been carefully considered, right down to the intuitive way the headphones turn on and off via folding. The ergonomic design delivers exceptional comfort for extended wear and sleek style.
Product Description Beats Solo Pro - headphones with mic
Product Type Headphones - Bluetooth - wireless
Recommended Use Portable electronics
Colour Black
Headphones Form Factor On-ear
Foldable Yes
Connectivity Technology Wireless
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 4.0
Sound Output Mode Stereo
Active Noise Canceling Yes
Controls Volume, answer/end, play/pause, next/previous track, audio transparency
Intelligent Assistant Siri
Designed For 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPhone 11, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod touch
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Beats Solo Pro Wireles...
£269.95
