Beats X Earphones - Black
FREE DELIVERY
£79.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Connect via Class 1 Bluetooth with your device for wireless listening
  • Up to 8 hours of battery life for when you’re on the go
  • With Fast Fuel, a 5-minute charge gives you 2 hours of playback when battery is low
  • Variety of eartip options offer personalized comfort
  • Flex-Form cable provides all-day comfort with easy bag and pocket portability
  • Authentic, clear acoustics deliver crisp sound fit for your life
  • Take calls, control your music and activate Siri with RemoteTalk
  • Accessory Type: Earphones
  • Connectivity: Wireless
  • Colour: Black
  • Stock Status: In Stock, Used Stock
Product codes
Fit for your life, Beats X earphones are the perfect wireless companion. Experience authentic, clear sound throughout your day with a long battery life. Their unique flex-form cable provides all-day comfort and easy pocket portability.
Product Description Beats X - earphones with mic
Product Type Earphones - Bluetooth - wireless
Compatibility iPhone, iPad, iPod, Mac
Recommended Use Portable electronics
Colour Black
Headphones Form Factor In-ear
Connectivity Technology Wireless
Wireless Technology Bluetooth
Sound Output Mode Stereo
Noise Isolating Noise isolating
Microphone On-cable
Microphone Operation Mode Mono
Controls Volume, answer/end
Designed For 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod touch; TV; Watch
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: DTMJ 040940
£42.87
product
Ref: DTMJ 040940
Accessories
Packaging
Functional
Software
Manuals
£42.87
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£79.99
