BeatsX Wireless Earphones - Black
RRP £129.99! SAVE £20
Colours:
Key features
  • Sleek, light and compact earphones
  • Authentic, clear sound
  • Optimized noise isolation
  • Immersive listening experience
  • Fit for your life
Product codes
Fit for your life, Beatsx earphones are the perfect wireless companion. With up to 8 hours of battery life and Fast Fuel technology, you can experience authentic, clear sound throughout your day.
Apple W1 Chip
Beats and Apple are changing the way you listen to music with the introduction of Apple W1 technology in BeatsX . Incorporating the incredible W1 chip brings seamless setup and switching for your Apple devices, amazing battery life, and 5-minute Fast Fuel charging.
Requires iCloud account and macOS Sierra, iOS 10, or watchOS 3.
5 Minutes of Charge = 2 Hours of Playback
With Fast Fuel, 5 minutes of charging gets you 2 hours of playback when battery is low.
Take Calls With RemoteTalk
With Siri-compatible RemoteTalk, you can take calls with an on-cable mic and play music with easy-to-use controls, seamlessly switching back and forth as you go about your day.
Flex-Form Cable
The unique Flex-Form cable provides a flexible fit for all-day wear, while a variety of eartip and secure-fit wingtip options offer further personalized comfort and stability.
Authentic, Clear Acoustics
From listening to music to taking calls, clear acoustics deliver an authentic listening experience, no matter where your day takes you.
Up To 8 Hours Of Battery Life
Beatsx features an 8-hour battery powered by the Apple W1 chip so it is ready when you are. Whether on the go or at work, you can enjoy wireless listening throughout your day.
What's in the box?
  • BeatsX earphones
  • Eartips with four size options
  • Removable secure-fit wingtips
  • Pocket-sized carrying case
  • Lightning to USB-C charging cable
  • Quick Start Guide
  • Warranty Card
Product Description Beats X - earphones with mic
Product Type Earphones - Bluetooth - wireless
Compatibility iPhone, iPad, iPod
Recommended Use Portable electronics
Colour Black
Headphones Form Factor In-ear
Connectivity Technology Wireless
Wireless Technology Bluetooth
Sound Output Mode Stereo
Noise Isolating Noise isolating
Microphone On-cable
Microphone Operation Mode Mono
Controls Volume, answer/end
Manufacturer Warranty 1-year warranty
Designed For 10.5-inch iPad Pro; 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation); 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X; iPod touch (6G); TV; Watch
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
