Belkin Air Protect Chromebook and Laptop Case 14"
£78.90
Delivery:
Key features
  • Micro-gel and universal screen mount clips for stable hold
  • Multiple screen positioning angles
  • Durable exterior
  • Integrated carrying handle
  • Shoulder strap
  • Full port/UI access
  • 6-sided shock-absorption
Product codes
Secure and lightweight, the always-on Air Protect Case for Chromebooks and laptops lets you use your mobile device in its protective case.
The Belkin Air Protect Case for Chromebooks and laptops is designed for active classroom environments and safe transport inside and outside school. Work directly from this protective case without the need to remove your device, reducing potential damage.
These cases feature protective padding and reinforced stiffening that absorb impact, making the Air Protect the ideal classroom case for Chromebooks and laptops. Its durable exterior will protect your investment from tear and constant usage. Innovative universal connect technology keep your device, even in use, safely secured while providing a comfortable typing angle and full visibility of your screen. The non-slip EVA molded base elevates your device, ensuring optimum ventilation to cool operation, even after hours of constant usage.
A zippered front pocket accommodates storage for chargers and other accessories. When opening your Belkin Air Protect case, you will have direct access to charging ports and other connections on the sides of your laptop.
This simple one-zip solution ensures your device will be safe from shifting or sliding and makes powering-up easier and more efficient, without hampering screen visibility.
Air Protect supports full access to Wi-Fi. Side ports are accessible when the device is in use.
Air Protect cases are constructed to be durable and lightweight, with multi-layer cushioning to protect mobile devices against drops and accidental mishaps.
Belkin Air Protect Case for Chromebooks and Laptops - notebook carrying case
Notebook carrying case
Product Material
Molded EVA
Notebook Compatibility
14"
Shockproof, ID card window, tear-resistant, drop-proof, zippered front pocket, sleep/wake function, airflow back paddings
Carrying Strap
Shoulder carrying strap, top carry handle
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Air Protect Chr...
£78.90
