Belkin Air Shield™ Protective Case for Chromebook
£63.76
Delivery:
Key features
  • Universal fit for most 11-inch Chromebooks and compatible laptops/Ultrabooks
  • Internal shock-absorbing suspension system and multi-layer protection
  • Laboratory tested for impact and drop protection
  • Compact design fits most charging carts and backpacks
  • Full access to device ports, keyboard and display
  • Can stand device on side when not in use
  • Maximum compatible device dimensions (including device feet): 12.0” x 8.9" x 1.1"
  • Air Shield™ external dimensions: 12.9” x 9.8" x 1.35"
Product codes
The Air Shield Protective Case for Chromebook is uniquely engineered both inside and out to guard against damage from drops, bumps, and impact. An interior shock-absorbing suspension system centers and positions the device, ensuring that the rugged structural case always stays on. Tested and certified by independent laboratories for drops and backside display impact, this case meets the highest standards in the industry. It also enables complete access to your device's ports, keyboard, and entire display. A slim design makes for an easy fit in backpacks and most charging carts. When device is not in use, the case allows it to be placed on its side to free up valuable desk space.
Belkin Air Shield Protective Case for Chromebook - notebook carrying case
Notebook carrying case
Package Content
EVA foam
Product Material
Polycarbonate
32.7 cm x 25 cm x 3.4 cm
Notebook Compatibility
11"
Impact resistant, shock absorption, Thermoplastic polyurethane (TPU) liner, ports and controls access, drop protection
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Air Shield™ Pro...
£63.76
