Belkin BOOST UP Bold Wireless Charging Pad 10W - White
£45.75
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Faster wireless charging when compared to 5W charging
  • Optimized for Qi smartphones to protect functionality while charging
  • Universal compatibility for all Qi-enabled smartphones including the new iPhones, Samsung, LG, Sony, and other Qi phones
  • 1.5m/5ft AC adapter is included to ensure correct power output for optimal charging experience
  • Choose from 2 different colors to suit your style
  • Charges through most lightweight plastic cases – up to 3mm
  • LED indicates charging status or foreign objects such as magnetic cases or credit cards on charging pad
  • 2-Year Warranty
  • Additional 1-Year Warranty with registration of charging pad
  • £1,500 Connected Equipment Warranty
  • Meets all Apple required and preferred standards for wireless charging for added peace of mind
  • Type: Charger
  • Stock Status: In Stock
Product codes
Fastest wireless charging engineered for Qi
Fastest wireless charging for your Qi-enabled devices has arrived. The BOOST?UP Bold Wireless Charging Pad 10W delivers 10-watts for fastest charging and offers optimal wireless charging for iPhone X, iPhone 8/8 Plus, Samsung, LG, Sony and other Qi-enabled devices.
Save time with fastest wireless charging
BOOST?UP Bold Wireless Charging Pad 10W offers up to 10-watt wireless charging to optimally charge any Qi-enabled smartphone. This higher wattage means faster charging than 5-watt wireless chargers and standard 5-watt wall chargers typically provided with smartphone.
Qi is an established, evolving wireless charging standard owned by the Wireless Power Consortium (WPC). Their goal is to deliver wireless charging easily and safely, while ensuring compatibility across all devices that bear the Qi logo. All Belkin wireless chargers are developed to meet the Qi wireless charging standards as laid out by the Wireless Power Consortium. As a result, this fully Qi-certified wireless charger is compatible with all Qi-enabled devices.
Optimized for better performance
Specifically engineered to optimize performance for all Qi-enabled smartphones, the BOOST?UP Bold Wireless Charging Pad 10W not only charges at fastest possible speed but protects phone functionality while charging. Premium shielding and precision resistors found within this wireless charger minimize interference, ensuring battery life and critical phone functions such as network signal, touchscreen, Wi-Fi, Bluetooth and LTE are not disrupted.
LED light indicates proper charging
A soft LED light indicates when your phone is correctly aligned on the pad and charging. The light has been designed to not disrupt your atmosphere or interfere with sleep. When you see the white light, your device is charging optimally.
Foreign object detection
An LED light alerts you to foreign objects, such as keys or coins, on the wireless charger that could affect charging. Foreign object detection (FOD) helps to prevent the charger emitting unnecessary power and heat that could damage your smartphone and other heat-sensitive items. Placing magnetic mounts, metal cases or other objects between your phone and the charger might reduce performance or damage magnetic strips or RFID chips like those found in some credit cards, security badges and passports. If your case holds any of these sensitive items, remove them before charging or make sure they aren't between the back of your phone and the charger.
Case compatibility
Charge without removing your case. The BOOST?UP Bold Wireless Charging Pad 10W is engineered to work with lightweight plastic cases up to 3mm (not compatible with metal cases).
Product Description Belkin BOOST UP Bold Wireless Charging Pad - wireless charging mat
Product Type Wireless charging mat - wireless charging
Colour White
Wireless Charging Standards Qi
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin BOOST UP Bold W...
£45.75
