Belkin BOOST UP CHARGE Wireless Charging Pad 10W (with Power...
Belkin BOOST UP CHARGE Wireless Charging Pad 10W (with Power Supply) - White
£18.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast wireless charging for Qi-enabled devices up to 10W
  • Case compatible with most lightweight cases
  • LED light indicates when your phone is properly aligned for optimal charging
  • AC adapter included for charging right out of the box
  • Stock Status: In Stock
Product codes
Fast wireless charging up to 10 watts so you always safely get the fastest possible wireless charge. Just lay your phone onto the pad for a quick and easy power boost. Power any Qi-compatible phone using this single charger. The BOOST?CHARGE Wireless Charging Pad 10W has been engineered to charge Apple and Samsung smartphones at the fastest possible speed while delivering 5 watts to all other Qi-enabled devices. Charge without removing your case. The BOOST?CHARGE Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm.
Product Description Belkin BOOST CHARGE wireless charging pad - + AC power adapter - 10 Watt
Product Type Wireless charging pad + AC power adapter
Dimensions (WxDxH) 1.33 cm
Diameter 9 cm
Weight 74 g
Colour White
Wireless Charging Standards Qi
Power Provided 10 Watt
Cables USB type A to micro-USB type B cable - 1.2 m
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£18.46
