Belkin Boost Up Wireless Charging Pad 10W - Black
£38.68
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Optimised for Apple and Samsung devices, the Boost Up Wireless Charging Pad 10W is tuned to deliver the fastest possible wireless charging speed to Qi-enabled iPhone models at 7.5-watts, and Samsung devices at 9-watts. Just lay your phone onto the pad for a quick and easy power boost. Compatible with any Qi-enabled smartphone, the Boost Up Wireless Charging Pad 10W has been engineered to provide the fastest possible wireless charging speed to iPhone and Samsung devices, while delivering a standard 5W charge to all other Qi-enabled devices. A white LED light indicates your phone is properly aligned and charging, while an amber light alerts you to the presence of a foreign object like keys or coins. The light is specially designed to not disrupt the surrounding environment. Charge without removing your case. Boost Up Wireless Charging Pads are engineered to work with lightweight plastic cases up to 3mm. The Quick Charge 3.0-compatible wall charger and cable ensure optimal charge to your wireless charger. You can also connect Quick Charge-compatible devices to the wall charger using the included cable.
Product Description Belkin BOOST UP Wireless Charging Pad wireless charging mat - + AC power adapter
Product Type Wireless charging mat - wireless charging
Dimensions (WxDxH) 9 cm x 9 cm x 1.33 cm
Weight 74 g
Colour Black
Fast Charge Technology Qualcomm Quick Charge 3.0
Wireless Charging Standards Qi
Cables Micro-USB to USB cable - 1.2 m
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Boost Up Wirele...
£38.68
