Belkin BOOST UP Wireless Charging Pad for iPhone 8/8 Plus &am...
Belkin BOOST UP Wireless Charging Pad for iPhone 8/8 Plus & iPhone X
£80.95
Delivery:
Standard: 1-3 working days
Key features
  • Supports up to 7.5W charging
  • Charges through most lightweight cases
  • Non-slip surface helps secure iPhone X, iPhone 8 Plus, and iPhone 8
  • AC adapter included
  • Works with all Qi enabled devices up to 5W
  • 2-Year Warranty
  • Additional 1-Year Warranty with registration of charging pad
  • £1,500 Connected Equipment Warranty
  • Weight: charger 3.88oz / 110g
  • Weight: power supply 4.09oz / 116g
Product codes
The BOOSTUP Wireless Charging Pad acts as a new charging conduit for those looking to utilize the new and exciting features of iPhone X, iPhone 8 Plus, and iPhone 8 and the simplicity of wireless charging.
Unclutter your space and simplify charging with the BOOST?UP Wireless Charging Pad. Belkin worked closely with Apple to engineer an efficient and high-speed charging pad for iPhone X, iPhone 8 Plus, and iPhone 8—just lay your phone onto the charging pad and go. There’s no need to remove your iPhone X, iPhone 8 Plus, and iPhone 8 from its case when powering up, the BOOST?UP Wireless Charging Pad can charge through most lightweight cases.
Made for: iPhone X, iPhone 8 Plus, and iPhone 8
Belkin worked closely with Apple to design a charging pad for iPhone X, iPhone 8 Plus, and iPhone 8. Fine-tuned for iPhone X, iPhone 8 Plus, and iPhone 8, your phone won’t overheat or shut down prematurely. The 7.5W BOOST?UP Wireless Charging Pad is capable of faster charging output than standard 5W Qi™ chargers and won’t interfere with other operations of your iPhone X, iPhone 8 Plus, and iPhone 8.
  • Tuned specifically for the wireless technology in iPhone X, iPhone 8 Plus, and iPhone 8
  • Optimally charge your iPhone X, iPhone 8 Plus and iPhone 8, with no impact on your phone's functionality
  • Compatible with most lightweight cases
No more cables, no more messy charging stations. Simply place your iPhone X, iPhone 8 Plus, and iPhone 8 on the non-slip charging surface that’s designed to help secure your device while charging. Keep charging simple, even when your hands—and day—are full.
Is it charging?
Charge with confidence—a solid green LED light shows when your phone is correctly aligned on the pad and charging. When you see the green light, you can go about your day knowing your iPhone X, iPhone 8 Plus, and iPhone 8 will be charged and ready for you.
Case Compatibility
Charge without removing your case. The BOOST?UP Wireless Charging Pad is engineered to work with most lightweight cases.
Qi Compatibility
Qi is a wireless technology that uses inductive charging. The BOOST?UP Wireless Charging Pad has been engineered to be Qi compatible, allowing it to also charge phones, tablets and other accessories with Qi technology.
The Inside Story
Premium components inside the charging pad provide maximum efficiency and peace of mind.
  • LED light
  • Premium components inside the charging pad provide maximum efficiency and peace of mind.
  • 7.5W transmitter coil for faster wireless charging than standard 5W wireless chargers
  • Fanless design ensures quiet operation
  • Intelligent wireless charging chipset combines multiple sophisticated features for overall performance and efficiency
  • Thermal protection sensor provides safer operation
  • Enhanced foreign-object-detection circuit provides safer operation
Key Features
  • Fine-tuned for Apple so you know your iPhone X, iPhone 8 Plus, and iPhone 8 is always charging as quickly and safely as possible
  • Works with any device that is Qi enabled, allowing you to charge all your Qi compatible electronics
  • Case compatible with most lightweight cases so there’s no need to remove your phone from its case
  • LED indicates when your phone is properly aligned for optimal charging
  • AC adapter included so you can start charging right out of the box
At A Glance
  • Qi compatible
  • 2-Year Warranty
  • $2,500 Connected Equipment Warranty
Package Includes
  • Wireless Charging Pad
  • AC Adapter
  • Quick Install Guide
  • Extended Warranty Registration Card
Belkin BOOST UP Wireless Charging Pad - wireless charging mat - + AC power adapter
Wireless charging mat - wireless charging
1.46 cm
Diameter
11.86 cm
110 g
Wireless Charging Standards
Qi
2 years warranty
Apple iPhone 8, 8 Plus, X
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin BOOST UP Wirele...
£80.95
