Fastest wireless charging for your Qi-enabled devices has arrived. The BOOST?UP Wireless Charging Stand 10W delivers 10-watts for fastest charging and offers optimal wireless charging for iPhone X, iPhone 8/8 Plus, Samsung, LG, Sony and other Qi-enabled devices. Choose from four different color finishes to find the perfect color for your space.
BOOST?UP Wireless Charging Stand 10W offers up to 10-watt wireless charging to optimally charge any Qi-enabled smartphone. This higher wattage means faster charging than 5-watt wireless chargers and standard 5-watt wall chargers typically provided with the smartphone.
An original, thoughtful design makes it easy to align your device for fastest wireless charging in either landscape or portrait mode. From browsing a web page to watching a movie, it's easy to continue using your phone while you charge.
Qi is an established, evolving wireless charging standard owned by the Wireless Power Consortium (WPC). Their goal is to deliver wireless charging easily and safely, while ensuring compatibility across all devices that bear the Qi logo. All Belkin wireless chargers are developed to meet the Qi wireless charging standards as laid out by the Wireless Power Consortium. As a result, this fully Qi-certified wireless charger is compatible with all Qi-enabled devices.
Specifically engineered to optimize performance for all Qi-enabled smartphones, the BOOST?UP Wireless Charging Stand 10W not only charges at fastest possible speed but protects phone functionality while charging. Premium shielding and precision resistors found within this wireless charger minimize interference, ensuring battery life and critical phone functions such as network signal, touchscreen, Wi-Fi, Bluetooth and LTE are not disrupted.
Product Description | Belkin BOOST UP wireless charging stand | Product Type | Wireless charging stand - wireless charging | Colour | Midnight | Wireless Charging Standards | Qi |
General | |
Product Type | Wireless charging stand |
Enclosure Colour | Midnight |
Power Device | |
Power Provided | 10 Watt |
Wireless Charging | Yes |
Miscellaneous | |
Included Accessories | Power adapter |
Compliant Standards | Qi |
