Belkin BOOSTUP™ Wireless Charging Pad
£75.78
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 15W Qi Wireless Charging
  • Flat, stable charging surface
  • Foreign object detection
  • Matte surface grips device
  • Embossed ring shows charging area
  • Charges effectively through most cases (3mm)
  • Fanless heat-efficient design
  • Includes adapter with hardwired cable
  • £1,500 Connected Equipment Warranty
Product codes
Although the charger works wirelessly, it doesn't sacrifice speed. The charger can bring your phone's battery from zero to 100 percent just as quickly as a conventional, 5-watt wired adapter. With its 1-amp output, the charger delivers power to your phone smoothly and quickly.
You can easily slip the QI Wireless Charging Pad into a pocket or bag thanks to its compact, travel-friendly design. The charger features a small footprint and takes up a minimal amount of space on your desk. And with its elegant design and black finish, it can blend in with any home or office environment.
Product Description Belkin Qi Wireless Charging Pad wireless charging mat - + AC power adapter
Product Type Wireless charging mat - wireless charging
Image Colour Disclaimer The displayed product image may be a different colour
Output Connector Type Magnetic - on cable: Micro-USB
Wireless Charging Standards Qi
Cables Micro-USB to USB cable
Designed For Samsung Galaxy S6, S6 edge, S7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin BOOSTUP™ Wirele...
£75.78
