Belkin Car Vent Mount
£25.89
Delivery:
Standard: 1-3 working days
Key features
  • Securely mount your smartphone to your car's air vent
  • Rotates 180 degrees for portrait and landscape view
  • Low-profile mount works with most car vents
  • Adjustable brackets securely hold smartphones up to 5.5 inches even when in a protective case
  • Matte surface grips device
  • Cable management keeps cable at your fingertips
Product codes
The Car Vent Mount provides a safe, hands-free way to use your smartphone in the car. Vent Mount fits most large smartphones with screen sizes up to 5.5 inches with a protective case on. This cradle securely attaches your smartphone to an air vent on your car's dash for a convenient optimal viewing level - no suction cup or adhesive required. The Vent Mount rotates 180 degrees so you can use your smartphone in portrait or landscape mode.
Belkin Car Vent Mount - car holder
Car holder
Intended for
Mobile phone
Suitable For Installation
Car
Screen Size Compatibility
Up to 5.5"
5.5 cm x 5.9 cm x 3.3 cm
Apple iPhone 3G, 3GS, 4, 4S, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, SE; Google Pixel, Pixel XL; Huawei Nova, P10, P10 Plus, P8, P9; Samsung Galaxy S II, S III, S4, S5, S6, S6 edge, S7, S7 edge, S8, S8+
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£25.89
