Belkin DisplayPort to DisplayPort Cable with Latches - Male/M...
Belkin DisplayPort to DisplayPort Cable with Latches - Male/Male 3m
£43.08
Delivery:
Standard: 1-3 working days
Key features
  • High-resolution support of up to 4k x 2k (3840 x 2160) at 60Hz
  • Top-of-the-line all-digital audio/video cable
  • Max HBR2 bandwidth of 21.6 Gbps supports multiple displays
  • Integrated latches ensure a firm connection
  • Simple plug-and-play connectivity
  • Supports HDCP (High-Definition Content Protection)
  • Length: 3m
  • Stock Status: In Stock
Product codes
Belkin DisplayPort cables bring an all-digital, high-performance cable standard to life. DisplayPort cables provide the ideal digital display interface standard for maximum high-definition performance, all in one cable. This top-of-the-line technology delivers extreme refresh rates, intense color depths, and high resolution for all your computing display needs. With its compact size, Belkin DisplayPort cables will be the only high-definition, all-digital audio video cable a user will need for any DisplayPort-enabled digital computing device.
Product Description Belkin 10ft DisplayPort 1.2 Cable with Latches, M/M, 4k - DisplayPort cable - 3 m
Type DisplayPort cable
Length 3 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Designed For P/N: F1DN104W-3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin DisplayPort to...
£43.08
