Belkin Dual USB Car Charger 2 x 2.4Amp - Black
£16.69
14 left in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Features 24W/4.8 amp Car Charger
  • 2 USB-A Ports
  • Universal compatibility
  • LED light
  • Sleek black design
  • Connected Equipment Warranty up to £1,500*
  • *Belkin will repair or replace electronic devices damaged by an electrical charge while properly connected to this charger, up to £1,500.
Product codes
Keep all your devices powered up while on the road with the Belkin BOOST?UP 2-Port Car Charger. This sleek car charger allows you to simultaneously charge up to two devices, making it a great choice for keeping your whole family's devices powered up and ready while on the go.
Thanks to its two USB-A charging ports, the Belkin BOOST?UP 2-Port Car Charger ensures you never have to prioritize which mobile device needs charging the most. Great for giving your phone a little extra juice on the way to work or for keeping children's entertainment devices powered up during long road trips, the BOOST?UP 2-Port Car Charger has a sleek design that fits seamlessly in your car's charging port to keep the entire family connected.
The charger's USB ports are universal, allowing you to pair it with any USB-A cable. As long as you have the corresponding cable, you can use the charger with smartphones, tablets, cameras, portable battery packs, Bluetooth speakers, smartwatches, and more. The built-in LED light lets you know when your devices are charging.
Belkin BOOST UP Car Charger - car power adapter
Car power adapter
6.88 cm
Diameter
3 cm
Sleek black
Output Connector Type
2 x USB
Power Device Details
2 x - 4 pin USB Type A - 2.4 A
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin Dual USB Car Ch...
£16.69
