Belkin High Performance Category 6 UTP Patch Cable 5m
£5.54
Delivery:
Standard: 1-3 working days
Key features
  • Maximize your network speed with higher bandwidth and enhance your network for future expansion
  • Perfect for VoIP, video, and file transfers
  • Supports 10/100/1000 BASE-T
  • Supports 10GBASE-T (up to 50 meters)
  • Exceeds CAT 6 performance requirements - Performance tested to exceed 500MHz
  • 50-micron, gold-plated connectors ensure clear transmissions
  • Length: 5m
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Product Description Belkin High Performance patch cable - 5 m - blue
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Features Molded, snagless, staggered pin configuration
Length 5 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Blue
Designed For Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Belkin High Performanc...
£5.54
