With Belkin ScreenForce, it's easy to keep your screen as pristine and protected as the day you got it. Engineered to be stronger than regular glass, TemperedGlass provides resilient, hard-wearing protection for your screen. Manufactured using premium glass, it retains the smooth glide and feel of the screen, and is tested extensively to deliver the brightness, sharpness and clarity you expect from your tablet.
Product Description | Belkin ScreenForce - screen protector for tablet | Product Type | Screen protector - glass | Intended For | Tablet | Screen Size Compatibility | 12.9" | Protection | Scratch-resistant, impact protection, fingerprint-proof | Package Content | Cleaning cloth, screen protector, dust removal sticker | Product Material | Tempered glass (9H) | Thickness | 0.33 mm | Manufacturer Warranty | Limited lifetime warranty | Designed For | Apple 12.9-inch iPad Pro (3rd generation) |
General | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
